Hi
Try ronseal decking seal. i use this every year. its easy to apply as its thin like water. tyou can use a big brush and brush it on from a large tin or old bucket. do it on a warm day after pressure washing the decking and the decking is dry and it will dry in 1/2 hr.
you can get it clear, or in a dark stain!! forget the rest.. Liberon Deck Oil is the best
i use it on my fences, garden furniture..and decking ( well i would if i had decking lol ) and it lasts and lasts and .. oh you get the idea.
water it down for the first coat.. a little, and then 100% second coat, this will last for years, and will not flake nor fade, nor nothing and is UV stabilized
why do so many snipe and correct a simple yet silly error on a reply to one's OP on this forum
yes yes yes, sorry i meant to put "thin" and not water down. but one would hope that the person about to water down "DECKING OIL" would know they would need a thinner's to water it down as it were, and not actual "water" clue is in the item name and is in the description on the tin.
but a big thank you for correcting me on such a gravely important matter
let us hope the chap did not use milk to thin it down eh?
If you tell someone who is not a keen gardenener, decorator etc to water something down....they will probably add water, so yes....you should have said thin it down
