Decking risers without concrete footings
16 Dec 2020
Hi all,
Going to put decking down around my extension and although I've seen them before I've been looking at the decking risers (i.e the plastic circular feet) and looking at a couple of suppliers they are saying that there's no need for concrete footings for these and you can put them straight onto the ground (i.e soil) ? has anyone done this and were they stable ?
I'm thinking that it's one of things that's stronger the more feet you put in but thought i'd see if anyone has any experience ? my decking will be an L shape and each "leg" will be about 5m x 2.5m (if that makes any difference)
Thanks in advance
12 Jan 2014
Essex
It's all about spreading the load.
If the risers go into the ground then no problem (like the elevo), but of they just sit atop the ground then I'd say no.
At the least you'd want slabs under them to spread the load,
16 Dec 2020
Thanks...that's what i thought....had a look around and others says it's fine to put them onto soil/grass but you still need about 100mm of hardcore underneath
