Declogging Kitchen Sink Pipes.....take apart or use cleaner?
8 Sep 2010
South West Wales
Hi all
I have a problem with a blockage in my outside pipes, which I'll address in another post. But because of this I've also discovered that the pipes beneath the kitchen sink seem virtually FULL of thick dark matter - not dissimilar to thick mud!
I've not been having a problem with the kitchen sink. In fact, water seems to drain away well. But I don't like the idea of my pipes being full of this yuck....
So I wondered what's best.... To take all the pipes apart and clean them up individually, then put them all back together? Or to use something. I would prefer to use something like bicarb soda and vinegar if possible. But I do have some caustic soda and some sulphuric acid. Only want to use them if totally necessary.
More than happy to take a photo of the pipes if that would help?
Any advice very gratefully received.
Cheers
Max
Caustic soda , creates heat which removes any grease which is what usually collects all the crud. You can also get biological drain cleaners which eat the crud, supposedly.
If you can remove them and clean them easily fair enough,
the only real product that will shift it is ONESHOT but be aware its corrosive and you should be very very careful in using it, its sulphuric acid !
Yep that Oneshot has been abused in the past (see the news). Oneshot is more for things like paper, human fat, hair etc as it just dissolves it due it's acidic nature (91% sulphuric acid). Caustic soda is more effective on greasy deposits as its alkaline.
