Hello there, I will be decorating new pine skirting board before fitting.
Please help to confirm that this work sequence are ok:
1. fill any minor dents or knocks
2. lightly sand rough or filled area
3. apply knotting solution over knotts
4. apply 1 coat of Dulux Wood Primer
5. apply 1 coat of Dulux Satinwood
6. fit skirting board
7. apply 2nd coat of Dulux Satinwood
What should I use to clean off any 'dust' after sanding?
I have no experience of applying knotting solution. Do I just brush over once on the knotts only?
When priming, do I just prime over the front facing of the skirting and leave the back in bare wood?
Do I need to undercoat with Satinwood?
For 45 metres of 150mm skirting board how much Primer and Satinwood will I need?
I have about 2 litres of Dulux White Satinwood left over 2 years ago. Any problem do you foresee using old paint?
