Hi all,
A couple of tiling questions if you don't mind?
1) We have tiled all our bathroom walls with 60x30, 10mm thick white ceramic tiles. We have left a rectangular strip free where we want to put some red decorative glass tiles in the middle. I bought some mirror adhesive as you can't use standard adhesive for them but they are 0.6mm, so adding the white ceramic tile + the adhesive together there is about 1cm to level up the decorative tiles to the white's surface. Is it OK to use mirror adhesive to 1cm depth to do this? The wall is plain gypsum plaster. Or do I need to pad the wall out with something? Could I pad the wall out with the normal tile adhesive and then bond to that with the mirror adhesive? These tiles were pricey so keen to know what is best.
2) The bathroom floor is concrete. There is no protection on it and we want to tile onto it. Do I need to PVA it before doing so?
Cheers!!
Cheers!!
