design work for dentist sergery
5 Jul 2005
London
Hello all Viewer's
Im doing a project design for a two-storey dentist sergery, would appreciate help to select using manufacturer's data, select suitable luminaires for each area.( Using possibly data from Thorn Catalogue). all other suggestion appreciated.
Ceiling's are as follow. All ceilings are to be suspended 600mm*600mm grid with romovable tiles 2400mm above floor with the exception of the store room, and some emergency lighting too.
The incomming supply is 400/230v 50Hz three phase four-wire, which together with the installation forms part of a TN-C-S System. The declared value of Ze is 0.06 ohms and the prospective fault current is 7KA.
Area's as follow:
Ground floor/ Location = Area squared--First Floor/Location/Area Squared
Treatment Room = 12.02 / Office = 7.38
Hallway = 54.69 / X-Ray = 6.05
Store = 1.68 / Store 1 = 2.60
Electrical intake = 4.00 / Dentist Room = 30.59
Sergery room = 27.29 / Hygienist = 12.68
Pactice manager = 12.26 / Admin = 15.24
Admin = 35.55 / Reception = 20.14
Waiting area = 69.17 / Treatment Room 1 = 19.80
Pharmacy = 22.60 / Staff area (main) = 29.31
Secure store = 6.27 / Staff area(corridor)= 2.40
Nurse room = 13.65 / Kitchen = 6.74
Health visitor = 13.00 / Treatment room 2 = 26.70
Stairway = ----- / Store 2 = 5.13
Lobby = 11.38 / Landing = 4.75
Gent's Toilet = 3.60 / Stairway = ----
Disabled Toilet = 3.75 / Waiting area = 87.40
Ladie's Toilet = 3.60 / Dentist 2 = 38.93
Thank's in advance
50p says you won't get anyone here to do your homework for you.
If you get stuck on a particular point, please feel free to ask again.
Most manufacturers will offer a free design service, as heating maunfacturers offer a storage heating design service.
Try your local wholesalers.
With christmas here am looking for all the help i can get on this subject due to time constraint's.
thank's all
You mean you didn't start soon enough and now you need other people to do some of your work or it won't be finished on time.....
Sham..your either doing a college course project or your not a truly qualified sparky..
Why do I say that..what your asking is a couple of hours work..perhaps half a day at most for a decent spark/engineer...
If your doing a college course, then I am afraid to say that you will learn nothing by getting others to do the work for you..and with respect to most here, this is a DIY forum not a professional one, although there are many competent members here and some qualified ones, this is not the correct forum for such discussions. However if you do the work, there is nothing to stop you asking others here to check it to see if your correct...but do it first yourself or you won't learn.
If your a tradesman and looking for a leg up as you have forgotten to do the design or cannot do the design..well tough..why should people here help you earn a living when you are either too lazy, disorganised or incompetent to do it yourself...
Thank's all, i have started the design work as you will notice i have got the area measurement from A1 plan, which is in scale 1cm to 50cm.
however the next stage is a bit complex and require's manufacture data which i need to obtain soon as. Then next to calculate maximum demand.
The project is for college guy's not to earn a living unfortunately.
Sham
Sham
in any case you dont learn by gettin someone else to do your work. do it yourself, and if you have any problems, then come back and ask our advice.
Thank's all
Waiting for lighting software so i can measure lumen for area.
Any sugestion how to get a copy from manufacture's as have tried but haven't recieved one, and any advice on lumen calculation?
sham said:
Thank's all
You won't get anything from the manufacturers...they all use their own software and it is tailored to their lights, they guard it with their life..
Regarding the Lumen calculation...have you tried GOOGLE...??
http://www.lighting-technologies.com/Products/LumenDesigner/calculate.htm
http://www.ndlight.com.au/lighting_calculations.htm
And these are gems
http://www.cooper-ls.com/dg_ltgdesguide.html
http://www.guth.com/products/pdf/t12.pdf
http://www.hubbell-ltg.com/products/psgpage/technical/floodlighting_concepts.pdf
Thank's big_sparks, can you give me some example say for the first room,
which is the treatment room, area size 12.02 sq metres?
cheers
