I've just started replacing an old metal fuse box in the garage for a modern RCD CU, however the feed from the house doesn't appear to have an earth cable (only 2 core) although it is SWA which is glanded off so I suspect that has been providing the earth.
I've checked the cable that feeds the garage at the house end and it has an earth connection but is an internal grey t&e cable so i assume it must be joined somewhere as it is presented in a black cable within the SWA.
Is it an option to connect the garage end with a banjo/earth tag and take a earth connection to the earth bus bar of the new CU?
New CU is plastic by the way..
