- Joined
- 22 Jan 2007
- Messages
- 8,525
- Reaction score
- 4,533
- Country
So this is just more of a curiosity.
With inverter driven heat pumps, you may have a 30ma Type-B RCD. Specced so that if there was variable frequency earth leakage it would trigger at different times. i.e if its was earth leakage at 50 Hz it would trip at or above 30mA. If it was above 1 kHz leakage then the trigger point would be 150mA etc.
So if you had an RCD intermittently tripping on a heat pump system as above, you might put clamp round the L&N feeding the appliance and see 100mA of a difference.
How could you know if this was happening at high frequencies and everything's working at normal, or lower frequency's and the RCD should have already tripped?
Can you know? Is there more advanced testing equipment available than the standard earth leakage clamp to test for this sort of thing?
