Guys, started what I thought was an easy job of changing and moving an old cylinder and its became a nightmare..
think at 1 time this house had coal heating but new system had been put in and old cylinder left.
right now thought it was simple FLOW & RETURN, COLD FEED AND HOT WATER DRAW OFF + VENT.
NOT QUITE THIS OLD CYLINDER HAS 5 PIPES ????
Everything normal but where the cold feed enters it seems to branch through an old chimney breast as well then returns back through into the cylinder above ??? well apears that way anyway..
anyway I though take the old one out cut all the pipes and repipe a standard 4 pipe cylinder, all went well until I filled it and water started coming out the old pipes I had cut from the 5th pipe and where the cold feed branched off.. to me it seems this is connected to the DRAW OFF and its just like an open tap pouring out. For the life of me I cant understand how this is connected, must be somehow on the DHW DRAW OFF so I need to cut the old brick out to get in and cap...
has anyone came accross this type of cylinder and can anyone explain the piping as its nowt ive ever seen ??
