Hi guys
I hope someone can help me out here as I'm struggling to find an answer. I've very recently had my heating changed from a gas boiler to an electric heat pump and, as part of this, the plumbers have taken out the existing 210 litre thermal store (Nu-Heat EnergyMaster) that supplied the hot water for our heating system and heated our DHW as it passed through, (apologies for the explanation if it's not necessary - just not sure that I'm using the correct terminology). They've replaced it with a traditional hot water tank.
The tank is in our attic and there's restricted space so the plumbers were meant to supply a custom built tank that was created to the max dimensions that we could easily get up there, (ie through the loft hatch), whilst retaining as much capacity as possible. We only realised after they'd installed the tank that it was actually just a slim-line 150 litre tank and we're concerned that this just won't hold enough hot water for us - we're a 4-person household.
We're not hugely impressed with this as it isn't what was ordered and are worried that it'll be less efficient and that we'll run out of hot water. However, they're now claiming that this 150 litre tank can supply more 45 degree water than our old 210 litre thermal store, (which was at 70 degrees with a max flow rate of 26 litres/min to raise cold mains water to 40 degrees). Is this correct? I don't even know where to start to work this out so would hugely appreciate any knowledgeable people helping me out here. If that's right then perhaps we don't need to worry?
Any thoughts?? Thanks in advance...
