Diamond Core Drills
11 Jun 2004
Can anyone recommend a decent set of diamond core drills (ie Make) have seen the Norton ones in srewfix any advice cheers
cant really go wrong with the norton ones - very trustworty :D - just make sure you still them in a drill which is capable ie one made for diamond core use - and NOT sds
screwfix is a touch expensive though - shop around (by the way - i thought that advertising wasnt allowed on this forum ???)
I'm curious - why not SDS?
Have you seen this: http://www.diynot.com/advertise/ ?
two probs with sds really
they dont ahve a particulary torquey motor ( most of the power is in the hammer which of course you dont use with a diamond core)
other prob is that the clutch kicks in a bit late - i have seen a few broken arbors in my time - better that than a sprained wrist when a 5" core jams though
sds is ok up to 3" but over that you're pushing your luck
Good make Marcrist and I'd agree with the advice on drill sizes. I've used an 850watt industrial SDS on diamond cores up to 3in with success, but I've been put right by others on the bigger stuff. To drive 4in and 5in cores you need 1300 to 2000watts and a good clutch, so a bit beyond the range of an SDS, really. Makita do a reasonable diamond core drill at a good price - personally I'm still hiring for the rare times I need one.
Scrit
Good point, but I find my Metabo SDS is ok, clutch is a good`un
The best diamond drills on the market in my opinion are Nimbus diamond,Marcrist are good as are norton and turbolite were ok but as with most things you get what you pay for and Nimbus are the best.
I've got a set of bosch diamond core drills, they're great!
Kev
