The initial plan was to remove the old plaster (1910 stone built home) where it was loose and either overboard or drop the ceilings where required. It was old lathe and plaster.
Well in the end I had all the old plaster removed from all walls - in and around the door frames some of the bricks have come loose and though the walls are solid - was taking off the old plaster- making a bigger jobs than necessary than just skimming over the old plaster?
Now the whole house will be getting new plasterboard.
Can I add loft type insulation underneath the first floor which is not exposed from below as the ceiling has been removed.
