Some of you may remember I asked about a 9.5Kw powerstream which is on 6mm2 cable and 45A fused at CU. I thought this was a bit thin and you all agreed.
So trying to get a quote for running 16mm2 cable to allowfor a more powerful powerstream (the 9.5Kw is broken anyway), and downloaded the Powerstream hand book.
It states for the 10.8kW and 12kW units:
If the cable length (ie approx 15m) indicates 16mm2, what will reducing to 10mm2 between DP and unit do? Should I just stick witht eh 9.5kW unit and put in 10mm2 all through?
As a side issue, the powerstream handbook also suggests that 6mm2 cable is sufficient for the 9.5kW unit if surface run and less than 10m.
This unit has been designed to accept 10mm2 supply cable. Therefore this is the size of cable that should be used between the isolator switch and the unit, even if you decide to use 16mm2 between the fuse box and isolating switch.
