Digimix Shower Unit
10 Nov 2020
Hello,
I hope everyone is well.
I am having some issues with my Creda Digimix Shower. It works but it is not reaching the correct temperature.
For example, the range is 1-9 with a L and H setting. The normal range has always been 5/6 and this produces hot water. However, recently any setting from 1-9 the temperature is just warm, once you set it to the H setting the water heats up to the temperature it would be if it were at setting 5/6, however it then errors after a few minutes which I can only assume is due to the overheat sensor.
I have no idea why the unit will not meet the desired temperature at settings 5/6 as normal.
I know with these showers it is probably more cost effective to replace the unit, but this unit appears to have bene discontinued. Would changing the PCB in the unit solve anything or is this wasted expense?
Any ideas on what I could try to get the shower operating as normal again?
Thanks for your help and advice!
