Digital Radio
29 Oct 2006
Lancashire
I don't know about you but when I switch mine on sometimes it says " No Stations available " so what is going to happen when the do away with AM/ FM etc
Am I only going to be able to listen to radio on a Monday when the weather is good, but Sorry not this Tuesday, Maybe Wednesday etc..............
Back to the old favourite Chezzer
It's "New Improved"; two words that no longer belong together in the English language
I think DAB will be "done away with" long before AM/FM from what I am hearing.
I started out with a Pure 1. Reception was Ok but I found the sound "muffled"
Sent it back and got a bigger Intempo, with 2 fair-sized speakers. Still muffled on DAB. OK on FM.. Not as clear as my old Sangean portable. It eats a set of batteries in a day.
I've since found out that most stations transmit a poor-quaity signal (128-bit I think I heard) so sound can never be as good as a good FM signal.
I wouldn't recommend buying one unless the extra stations are really important to you.
Oddly, sound though my TV digibox on radio stations is OK.
Apparently there is a new (incompatible :roll: ) DAB standard coming out which is better. But I hear UK has the best take up rate (still not very high) and it is likely to fade away like 8-track and Betamax. Unless it gets so cheap they put in in car radios at no extra cost.
The idea behind digital radio, as with digital TV, was to broadcast more stations in the same bandwidth but it was never going to work. Analogue broadcasting makes very efficient use of bandwidth. The down side is that there is no possibility of error correction so noise cannot be distinguished from valid data. To maintain data integrity in the face of signal degradation you have to digitize - and up goes the bandwidth.
Consider the bandwidth of CD quality audio. 44,100 samples per second at 32 bits each consumes over 700 kHz - and that's without error checking! The same information could be broadcast using SSB in a 44 kHz slot. FM, as actually used by analogue radio, is more wasteful but it's nowhere near as bad as 700 kHz. The same problem arises with digital TV and the solution is the same; compress the data.
Analogue TV consumes about 6 MHz per channel. That's enough bandwidth to transmit digital data at 12,000,000 bits per second. Now look at DVD where you can get eight hours of TV, complete with error checking, onto a 4.7Gbyte disk. That's about 1,400,000 bits per second and yet the quality easily outstrips analogue TV. That's why you can broadcast six digital TV channels and several radio channels in a single UHF slot.
Audio does not compress so easily. MP3 at 128 kbits per second is just about good enough for the average listener but it takes 65536 kHz of bandwidth to transmit - and still no error checking. Audiophiles expect better from their new digital radios so let's try MP3 at 320 kbits per second. With error checking on top you're pushing 200 kHz per channel which is on a par with analogue FM. Yes, you can have noise-free radio but you can't get more channels in without sacrificing quality.
If you want high quality radio at home you can get it through your TV digibox. If you want a vast choice of stations you can get them on the internet. If you want high quality radio on something you can carry around then, and only then, do you consider DAB. More than anything else, two factors have killed off DAB: the receivers have been grossly overpriced and quality has been sacrificed big time. I'm pleased to say that I never bought one.
I think it depends as to where you live, I've got a pure tempus 1 xt that sits on the the bedside table reception is crystal clear and serves as an alarm.
same position an fm radio wont pick up radio 2 or radio 4, now i dont need to having radio7 and planet rock :lol:
what i have noticed are internet radios coming onto the market, presumabley these latch on to your wireless router?
perhaps thats what the future holds :?
