Hi
I have a 2 way switch covering 2 seperate lights in my livingroom. 1 switch for one light the other switch for the other. These are not low voltage but mains. I have just bought a Dimmer 2 way switch to replace the original switch but do the same thing. On the back of the original switch the wires are coloured Blue Yellow and red. The Blue goes into one side of the switch and the yellow the other side. The red wire goes into the same side as the blue and links the 2 switches together. The confusing part is the red wire is red until it gets near the switch and then connects to terminal block and then changes to earth wire as is the link.
The dimmer has 2 switches with connections at the rear marked C,L1,L2. How do I wire this switch up.
Obviously the power will be disconected at the breaker box before doing any wiring.
