Hi there could anyone help?
A friend has told me that the lights in her kitchen have all stopped working.
They consist of :
2 ceiling lights consisting of cascading type chandeliers, separate switches for each.
1 set of under cabinet lighting with two way switches one at each end of kitchen
And finally two wall lights operating off one switch.
A total of 4 dimmer switches to control the lighting in the kitchen.
All lights seem not to operate exept for the wall lights which seem to flicker very dimly when the dimmer for them is switched and operated.
Ive had a look at the back of each switche which are located one above the other on the wall. the common is looped from one switch to the next and next and so on.
the switch wire in each dimmer seems to be constantly live.
I solated each switch in turn from the others and then used a normal switch to test if any of the lights would work..with no look.
Could anyone explain what the problem may be.
The downstairs lighting operates fine and is wired on the same lighting circuit.
I'm stumped as to what may be the cause as all the kitchen lighting went together.
Any advice greatly appreaceated.
They consist of :
