Diode porblem with a 12v TV
25 Oct 2012
Dorset
Afternoon All,
Ive been diving into a 12v TV for a friend and after some fault finding I've found a Diode that is not doing what it should.(I've bypassed it and the TV works so definite DIODE) I know I can buy them from Maplin for around 50p but Im unsure as to which diode it is.
Ive tried uploading a photo but cant seem to get it on here. If I manage to get it uploaded I will add it later on.
Any idea what type it might be? On the circuit board it looks like a Black Resistor albeit slightly chunkier(definitely a diode).
How can you be sure it is a diode ?
If bypassing it enables the TV to work then it is open circuit. If it is open circuit how can you tell it is ( was ) a diode.
It might have been a fusible resistor or a suppression choke if it is in the power supply .
Or it might have been a diode intended to protect the TV from reversed polarity supply.
If it was a diode to prevent reverse polarity then a 1N4001 will probably be OK for a small TV ( one amp from the battery )
Hi Bernard
Sorry I should of said it was open circuit. I think my friend said when he broke the 12v power supply he accidently wired it reverse polarity before he realised the centre pin was ment to be the +ve. That's when he asked for help. So I had a feeling it was the diode, but bypassing it confirms that.
Its nothing to do with the power supply, its just on the circuit board.
Saying that, usually there is a line on a Diode annotating which side the Cathode is on, but there isn't.
I really need to get this picture unloaded !!
I (like bernard) still don't really understand how that makes you so sure that the component in question is/was a diode. It's actually quite unlikely that reverse polarity supplied to the TV, per se, would destroy a diode within it - and if it had been a diode there to protect the TV against a reverse polarity supply, it obviously would not be damaged by reverse polarity.
As you say, a picture might possibly help. What is the uploading problem you're having - it's a simple enough process.
Kind Regards, John
