- Joined
- 27 Jan 2008
- Messages
- 28,100
- Reaction score
- 3,408
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
My daughter has a dishwasher she wants plumbing in, however it is around the corner to washing machine and there is a central heating unit between two which is unused, but limits what can be fixed to the wall.
Water in simple Y connector will do, but will need extra long hose or connector, but not any real problem. It is waste water out which is more of a problem. She has a glued 40 mm pipe, which ends with an up section to which the washing machine pipe simply hooks in, I could cut and extend around two corners to dish washer, but would still be a stretch for the waste hose.
So a washing machine drain out kit would it seems fit the existing pipe, so question is can I simply get an extension on the waste pipe and not bother with any non flexible pipe?
Question is I suppose will a dish washer sense extra resistance to flow and cut out.
She is not intending to stop in the house long, so don't want to do more that required.
