Dishwasher CDA INTERGRATED
16 Oct 2008
Hi
I put my dishwasher on as normal one day, about 10 mins it started beeping continuously until I opened the door as soon as I shut it again it beeps. My partner has had it to pcs tonight its not letting water into the dishwasher, however the supply pipe isn't blocked, there is a blue thing which looks like a astma inhaler, a small motor thing which we are wondering if this is the problem???? The led start button flashes 4 times then pause then 4 times again...??
If it is can it be replaced??? and how expensive might it be, is it worth replacing or shall we look at getting a new dishwasher??
Any info would be great..I miss my dishwasher :cry:
Louise
Whirlpool machine rebadged. 4 flashes is a draining failure. If it's draining ok then the fault will lie with the water indicator (pressure switch) or main pcb.
Hi - Thanks for coming back to me, is the pressure switch, connected to the main water supply pipe??
Louise
