DIY custom shower tray?
25 Sep 2004
I have an odd shaped shower room which I'm going to gut and renovate soon. The odd shape means I can't get a shower tray to fit but as I'm tanking the whole area anyway, are there any issues with with building a timber shower tray? I'm thinking 18mm marine ply generously sealed plus the tanking kit should be okay but what about the drain area? Any thoughts?
Hi ceolmar :)
there is a wealth of info here if you use the search function ,
+ look here
http://www.impey-uk.com/aqua_dec/index.php
an here
http://www.concretewaterproofing.co.uk/en-gb/dept_105.html
I always built my own wet room substrate an used BAL WP1 Tanking System
http://www.bpindex.co.uk/manf.html?id=1060
after ripping up the old flooring ,you should put extra support noggins in the joists then treat/soak in wood preservative , lay your 18mm WBP,screwed down at 200centres then tank an tile
hope this helps :)
