Im in the process of buidling a Wetroom and will be putting the toilet Cistern in the loft (Cistermeiser flush master - electronic). I guess it will be like a High level csitern but with Infra red sensor to initiate the flush.
The problem I have is that I need a long flush pipe (about 2.3metres) and first considered constructing one using 40mm ABS pipe (43mm outside diamter - 40mm inside diamter) with a solvent weld bend. But ive since learned that flush pipes are 38mm outside diameter. All pipe work will be hidden in a partition wall so I dont want compression fittings to convert between 40mm to 38mm. I am after eiether a long 38mm flush pipe (1 peice) or 38mm solvent weld piping. Any ideas or is 40mm solvent weld pipe (OD 43mm) likely to fit in the flush cone OK?
Any ideas / help appreciated!
