Hiya
First post, new to DIY so excuse any ignorance. Hopefully get some advice and can start on the road to having fun with DIY.
So existing bathroom tiles simply came up when checking, grout cracked, tiles broken. On investigation the tiles were put directly onto the floor boards, spacers left in and possible incorrect grout used / adhesive used.
I need to do a patch job firstly but also want to think about how to do it right in the future.
Research has pointed at the following:
1. Ply the floorboards to form a solid base - leave gaps around edges, stagger boards. Lots of screws - not long so not to pierce pipes.
Q. Do I need to ply under the bath?
Q. Do I need to prime or seal anything? Ie. the gaps of the boards?
Q. Should I silicon between the floorboard gaps to aid draft reduction?
Q. What thickness of boards - bathroom is 2.4m x 1.8m
Q. Do I tape the joins also? What Tape?
2. Adhesive - flexible - fast setting - 20mm trowel to apply - stagger tiles so grout line does not meet joins of ply
Q. Best adhesive to use - premix or powder?
Q. Should I get mould resistant etc?
3. Tiles
Q. What thickness of tiles is best? Does it matter?
Q. 4mm spacers?
4. Grout
Similar queries to Adhesive really - whats the best to use for floor in bathroom - want it to be mould resistant and maintain colour etc.
5. Sealant - I have seen these sealer pens to keep the grout longer - are these useful - recommended or just a waste of money?
6. Edges - silicon these up - what silicon is best for floors. Price ranges so much - heard latex is a great choice and more eco friendly I suppose?
Would like to look at making the project eco friendly - under floor heating a possibility? As I want to do it myself I can spend more on materials so if anyone has suggestions on cool gadgets to look at that would be great too.
Look forward to suggestions and setting the record straight on some of the research I have found.
Much appreciated
Ian
3. Tiles
Q. 4mm spacers?
4. Grout
Much appreciated
Ian
