Hi, I live in a 3 storey block of flats built circa 1970. It's flat roofed and all the floors are solid.
3 of the flats (2 second floor, 1 ground)are reporting damp problems which could be condensation, ie mould on outside walls usually near window.
My question relates to the outside walls which are quite large areas of brickwork, without an airbrick in sight. If damp gets into the cavity I assume because of the flat roof & solid floors there will be nowhere for it to escape to.
I know it might not ultimately solve the damp problems in the 3 flats but should airbricks be installed in the walls to allow the them to breath?
