Do i have the correct rated pump
26 Nov 2007
Midlothian
I bought a shower cabinet from ebay
http://cgi.ebay.co.uk/ws/eBayISAPI....m=250201487371&ssPageName=STRK:MEWN:IT&ih=015
I had it fitted by a friend of my daughter he is a corgi plumber & he seems to have done a good job, The only problem i have is with the pump, He had a spare pump which he sold me cheap its 1.5 bar but it does not seem to work properly, The shower cabinet has a multi connection at the back of the center pillar just below the control panel in the picture & the water goes to all the parts of the shower from here, When i try & use the overhead shower,handshower or body jets nothing happens the only time the pump will kick in is if i use the tap in the bath then turn the controls to the overhead shower or body jets, the hand shower will work if i turn the shower on then lower the hand shower to near the ground it will then kick in, am i correct in thinking that its gravity that is the problem & not the pump as i was thinking of buying a 2.5 bar pump but if its going to do the same there does not seem to be any point.
Thanks for any advice in advance.......... :D
It sounds as if the problem is with the available head from your cold water cistern.
Its possible that the flow switch can be adjusted but it might mean raising the cold water cistern.
Why not just accept that you have to hold the shower down to get the pump to start?
Or do what all customers do with their plumbers " call him back" !!!
Tony
