I've detailed the saga below, any advice and help would be very much appreciated, as I am a bit confused with what to do.
The story is that I have two radiators that aren't working in my house.
The first one stopped working back in Feb 2010, and then it was recommended that radiator be cleaned out, after which it started working again, however a back in September it stopped working again.
The second radiator stopped working just under a month ago.
The first radiator is in the the downstairs front room, and the second one is in the upstairs front room, rooms are directly above each other.
The central heating system, including radiators and pipe work is all 4 years old, it has plastic pipes. 2 years ago I had a magnaclean fitted as well.
I had the thermostatic radiator valves changed, just incase it was those that was causing the problem, however it didn't do anything. All the other radiators in the house work perfectly.
I have a homecare agreement with British Gas, and they have recommended a power flush with a lifetime guarantee, for £600, will this solve the problem, or am I just being ripped off? Also, they haven't carried out a water sample test.
I have spoken to a few independent central heating contractors and I seem to be getting a lot of different views, but they all seem to agree on one thing, that British Gas may just be trying to rip me off. I've had one say that microbore (I think he said microbore)/plastic pipe systems shouldn't need powerflushing and that the chances are just a blockage in one of the pipes.
Any advice would be much appreciated as I don't know what to do
Thank you in advance
