Do I need to permanently remove room sensor?
31 Dec 2003
I have an Accenta system with room sensors in the top corners of many rooms. I wish to hang a corner cupboard in the same corner as a sensor. Can I locate it immediately below the sensor or do I need to permanently remove the sensor and if so how do I do that?
depends on where its hung as to what it will block out wrt to the sensor, a basic rule of thumb would be if you can see the full sensor it can see you usually.
Thanks. I can hang the cupboard below the sensor and retain full view of it.
Regards
Also, what about the area below and in front of the detector now blocked by the cupboard?
Is it now possible to move left/right below and therefore bypassing the detector (hidden by the cupboard?)
Yes, it's still possible to move around in clear sight of the sensor so should be OK.
