Do I need to protect partial fill cavity wall from rainfall?
9 Jul 2013
Birmingham
Hi, I am building a garden studio with partial fill cavity walls and am using celotex cavity boards.
Do I need to cover the top of the cavity as I build to prevent the cavity from filling up with rain water and to stop the celotex from getting wet?
Also will the celotex warp if it gets wet?
Thanks in advance.
Don't know what the manufacturer's recommendation is, but I had 6 boards of celotex-equivalent stored outside all through this winter, one end resting inside my partially-constructed extension (which quickly turned into a swimming pool when the rain started), and the boards that got wet were indistinguishable from new ones when I came to install them this spring.
And I certainly hope we're not supposed to keep the cavities covered, because I haven't been doing it. :)
unless you have waterproof bricks your cavity cant fill up with water,,,if it holds abit of water it will soon absorb or evaporate
celotex can get wet without damage being caused,,,as stated above you can store it outside
when bricklaying/blocklaying in wet weather its good practice to cover your walls with Hessian fabric so when you start laying again your on a dry course,,also stops rain from making fresh mortar running down your wall
