Hi
Having recently moved house I have removed 2 radiators for decorating and now need to put them back on. However, being unfamiliar with the heating system I don't know how to go about topping the system up when I have re-attached and refilled the rads.
Briefly the system entails a Baxi Solo WM 50/4 RS boiler (conventional) and a Copperform combination tank.
I have taken some very helpful advice off this forum and checked for a filling loop and red pressure vessel of which I have neither, so I assume that it is not a sealed system.
However, I have also checked the loft/airing cupboard etc and there is also no cold water storage tank either (as in a vented system)- so I am at a loss??
The only form of water storage I can see is the "Copper form Direct Mains Combination Tank". I note however, that this is split into two, with the top portion taking the form of a small cold water tank with ball-cock.
My query is could this small tank be the source from which the heating system would re-fill itself as fill the rads - or if not how would the system refill.
GD
GD
