Do I need to undercoat?
1 Jan 2010
London
Hi All,
Going to be painting all my sills and window frames. Going from a dark grey satin to white satin. Apart from giving everything a good rub down and caulking around cracks, do I need to apply an undercoat as some leading brands say not needed but would rather ask the professionals who do this every day. Also, do I caulk before or after undercoating / top coat?
Cheers
Daz
I always caulked after undercoat as caulk stuck better.
Waterbased satin will stick to old waterbased stain. Same goes for gloss.
As a general rule I always used an undercoat.
On old oil gloss use an adhesion primer.
Yeah it's said you don't need a primer with 180 grade sanding and a clean with a paint cleaner, but I always found it's a better job if you do use a undercoat.
