BG just assumed it was the pump and changed it and when that didn't work they went off to speak to the superviser then came back and said it could be blocked and we needed a powerflush costing £700 and £500 to trace where the blockage was.
We had already tested the room thermostat and the timer before calling BG, both made the pump switch on and off so we ruled them out as a possible cause.
A friend of ours has also said it could just be an air lock, if it is what do you suggest?
