Hiya Guys my old man just been on the phone and asked me to find out if being a qualified electrician is enough to be changing CU or do you need to be part p registered etc
No, changing like for like is only allowed providing there is no change in the characteristics. It is indended so you could change, for instance, a broken lightswitch in a kitchen without having to notify.
I imagine that he has an older type fuseboard and wants to put in a modern 'split load' type board.
Everything in that board is different. evry circuit will have a different characteristic because a B type BS60898 contact breaker behave differently to a BS3036 rewireable fuse.
Changing a consumer unit is a heart & lung replacement for a house and is notifiable under Building Regulations Part P.
Not so. A full inspection and test is required and an electrical installation certificate should be issued.
It is also, definitely, a notifiable job, so you must either submit and pay for a Building Notice in advance, or have it done by a registered contractor.
(Edit: TTC got in while I was chucking my spollink!)
