As a qualified approved electrician due to redundancy I'm looking at the possibility of going self employed as a domestic installer, is it possible for me to do installation work and have it signed off by building control until i get registered with a part p agency
Yes it is! possible, there will also be installations that will not need to be notified. So BC will not need to be informed.
If notification is required. You will need to pay fees for applications/notifications though, they do vary from region to region, so I would enquire about them at your local building controls office.
I would also start to the registration with a scheme provider asap, as they do take about 6-8 weeks before they do your assessment.
If I was going recommend one, through experience I would suggest you contact http://www.partp.co.uk/
so for a few months then I will be doing installations for people and then a suit from the local authority will arrive inspect my work and hopefully sign it off, if a non compliance is found does this incur a second inspection with an additional charge?
Your local guys may well accept that you are competent to issue EICs and happily take those and your money (you do know how much notification will either add to your prices or subtract from your earnings?) and send out the Building Regulations completion certificate without any inspection at all.
If you going to get three jobs that are notifiable in the first few months of starting you may as well register in a Part P scheme - especially if two are within ten miles of each other.
Even worse if you are adding a socket in a kitchen.
If you get involved with new builds or new extensions, there is normally an application in place be it either with the builder or the client.
Like I said in my first post, start thinking now about getting registered with someone, as it will be after Christmas before you get accessed and it's an expensive job notifying and you even lose work because of the fees.
As for building control visits, I have found they spend a little time with you, if they are happy the system is safe or safer than previously and you can show them how to do a Zs test and a RCD test you have cracked it!
Why try to get involved with notification directly yourself before registering with one of the schemes? It's not your responsibility to act as policeman for the LABC. Let the householder commissioning the work decide whether he wants to notify and pay the fees or not.
It's a bloody racket this part p millions of pounds being generated off the back of tradesmen, I agree control needs to be in place but this is a total shambles of a system.
So would notifying and paying the LABC and then adding the £200 to your bill. But if the customer doesn't care about notification, there's no £200 disadvantage.
