Hi Everyone
I am looking for some advice/comments on the best way forward -
We bought a new build flat in Scotland and moved in about 3 months ago. We have had endless snagging problems and the company (which is quite big) have been pretty useless in fixing them. Most worryingly, I uncovered a couple of problems with the electrics (when wallpapering I unscrewed a socket and one of the wires on the ring popped out - I also changed a light fitting to find that the outer sheath had been cut with side cutters and damaged the live and neutral wires, exposing the copper on both). I reported this to aftercare so it was on record. After speaking to neighbours and the site workers, I was told that they had fired the previous contractors as the work had been shoddy. On Friday I came home, switched on the wet electric central heating and sat down to read the paper. An hour later smoke started coming from the cupboard were the consumer unit is located. I turned the power of and found the cu to be melting above the heating mcb (50amp). We have been staying in a hotel since then, and the company sent out an "independent" electrician (he works for the housebuilder at a different site) and he said that two of the cables had not been tightened into the mcb for the heating. I would not let him do anything other than look as I really want to get an independent report as we may have to take legal action against the builder. I am amazed that given they new that they had a dodgy electrician they did not recheck is work, esp after I had complained about the installation.
Could you advise me on the best way forward as I really want to build a water tight case against the builder. Should I go to building control and get a copy of the test certificate?
Any comments would be gratefully received. My gf is pretty unhappy as things could have been a lot worse, esp if we had been sleeping at the time.
