Dodgy mist coat advice
16 Jun 2006
London
As much as I love this site, I stumbled across the following
The article starts off well, explaining the importance of reducing the level of suction, recommending that readers follow the thinning instructions on the tin... and then...
A rather common recommendation is to take a 50/50 paint-to-water solution, but this is not without its disadvantages:
  • The mix can be too thin, and the plaster will absorb it right away, which may lead to some patchiness.
  • Getting good coverage might be a problem, and you may need to apply more coats.
You omitted to mention that if the mist coat is too thin when the full fat paint is rolled over the pseudo mist coat, subsequent coats of full fat might rip the previous coat off because the mist coat did little to nothing for the level of suction. I have lost count of the times that the builder has done the 50/50 before I turned up. I didn't notice until I applied the second full fat coat with a roller and sheets of paint started ripping off
The 50/50 recommendation should be sent to room 101... along with recommendations to apply thinned PVA to new plaster.
Oh, and recommendations to use dilute "contract matt" are wrong on many levels (not a recommendation on the linked page). The low latex paints are designed for plaster which is still slightly damp. They do zero for the level of suction.
Sorry, end of rant... and thank you for the site.
