Dodgy mist coat advice
16 Jun 2006
London
As much as I love this site, I stumbled across the following
The article starts off well, explaining the importance of reducing the level of suction, recommending that readers follow the thinning instructions on the tin... and then...
A rather common recommendation is to take a 50/50 paint-to-water solution, but this is not without its disadvantages:
  • The mix can be too thin, and the plaster will absorb it right away, which may lead to some patchiness.
  • Getting good coverage might be a problem, and you may need to apply more coats.
You omitted to mention that if the mist coat is too thin when the full fat paint is rolled over the pseudo mist coat, subsequent coats of full fat might rip the previous coat off because the mist coat did little to nothing for the level of suction. I have lost count of the times that the builder has done the 50/50 before I turned up. I didn't notice until I applied the second full fat coat with a roller and sheets of paint started ripping off
The 50/50 recommendation should be sent to room 101... along with recommendations to apply thinned PVA to new plaster.
Oh, and recommendations to use dilute "contract matt" are wrong on many levels (not a recommendation on the linked page). The low latex paints are designed for plaster which is still slightly damp. They do zero for the level of suction.
Sorry, end of rant... and thank you for the site.
Yes what do we do I've got some bare plaster I need to paint, saves me starting a thread.
So what do we do instead?
As the first part of the article says, I would dilute the first coat according to the instructions on the tin of matt emulsion (note: not contract matt). I really don't understand why people on youTube think they know more about dilution rates than the company who makes the paint.
If the first coat is too thick, too much of the water gets sucked in to the plaster rather than evaporating off. Water-based paints cure through a process called coalescence- as the water evaporates off the molecules flatten down and bond together.
If the first coat is too thin, the second (full fat) will soak in too quickly and the coalescence process will "fail".
If you are painting the wall by brush, it is less of an issue. When you use a roller, the air is expelled from the roller as the paint is applied. If the previous coats have not cured properly the roller may well pull off the paint.
Erm, respect to the @mods for updating the page that I linked to but you now recommend using contract matt even though I expressly recommended avoiding them on dry plaster because they do little for the level of suction.
When discussing contract matt, I might have muddied the water by referring to them as low latex. When talking about waterbased emulsion, latex and vinyl are generally interchangeable. I suspect that the author was trying to discourage people from using vinyl silk as the mist coat- if so, I would agree that vinyl silk should not be used as a miss coat.
I appreciate that I am only one of the many professional decorators on this site and that others might disagree but I would be interested to see what @Wayners has to say.
Overall, the advice page is improved, but, with respect, it still needs more work.
Regards.
3 mins in. Discussed.
What the paint manufacturers say is contract matt has one purpose. To paint damp plaster.
Then on new builds 6 months later when dry light sand and seal with gardz or 10% to 20% water with a durable matt to seal the contract matt.
Over plaster if dry mistcoat plaster with the durable emulsion the 2 full coats although you can add a splash of water to allow it to flow on warm days or if you need it.
That's correct way now. Make your own mind up I guess.
Delamination of durable paint can happen if you apply incorrectly
