Yes that is what I meant, a human regulates the intensity of the gas hob ring by turning a button, does the boiler also regulate its burner's intensity ? The answer seems to be yes. I will consider this if I decide to install a boiler rather than a heat pump.
Not all do.Heat pumps modulate compressor speed, and therefore output, too.
Not all do.
Most modern heat pumps with inverter drives (Vaillant, LG, Mitsubishi etc) do this typically over a range of 2:1. Boilers will typically turn down by a ratio of 5:1 or more. This is not as significant as it might sound because boilers are often over-sized to meet the hot water demand not the heating.Yes that is what I meant, a human regulates the intensity of the gas hob ring by turning a button, does the boiler also regulate its burner's intensity ? The answer seems to be yes. I will consider this if I decide to install a boiler rather than a heat pump.
