Does a gas hob really need to be wired into the mains?
5 Dec 2013
Midlothian
I was looking at replacing a new gas hob, like-for-like with one coming out. The hole size should be okay.
I noticed that most new gas hobs say in the manufacturers notes that they need to be hard-wired into the mains for the spark ignition thing. Is this really needed for building control regulations? I have a handy 13am plug socket in the space under the hob, will a gas fitter be happy if I fit a plug and plug in the cooker, it is only needed for ignition, hard-wiring seems a bit OTT to me. ( I live in Edinburgh).
I haven't bought the new hob yet. An example is the Hisense GM642XHS Gas Hob, available from Argos at the link below. The blurb on the Argos website says "requires hardwiring into a dedicated circuit ".
Quite a lot of similar gas hobs say they need to be hardwired into a mains circuit. Is it really a requirement or are they just not wanting to avoid the expense of fitting a plug? Or is it something to do with the system that prevents gas coming out if the flame is not present?
There will indeed be an electrically operated valve that shuts off the gas if there is no flame detected. So the regs will require hardwiring to eliminate the possibility of a plug being pulled out - which would defeat this failsafe system.
Can the gas fitter connect the wires? Or do I need an electrician as well? I have a socket for a cooker underneath the hob which has been checked by an electician (I was thinking of getting an electic cooker) but he didn't give me a certificate to say it is okay.
Yes, that is no problem at all.
New one on me. Most, if not all use a thermocouple.
Link not working, but I think the info is wrong having read the instructions
Most gas hobs that have FSD's have a thermocouple attached @ the burner, that generates enough of a current to hold the valve open, if the flame goes out, that current is lost, and a spring shuts the valve and gas supply down - No need for electrics.
The power supply is usually simply for the spark generator to light the appliance, connected through a plug or hard wired
perfectly normal to have a standard gas hob on a plug but use a 3 amp fuse ,
if it was hard wired it wouldnt be on a 3amp circuit
