I want to remove a domestice gas meter from a property and cap it off, does any one know what the gas pipe cap that BG uses is called, and the special tool they use and where I can one from
Yes the cap is called ('utno.1) available in most pound shops.
The tool is a 'ground nut artifical anoxide yuletide capacitating capaitor.' You will find them here... www.idiotondiynot.fr
