Pretty simple question. On a structural drawing, does the term span (in relation to an opening) include the bearing either side? A span of 2.2 m for example..... would that be 2.2 open or say 1.9m open with 15cm bearing each side.
Typically it's the clear span between supports, but in some structural calculations it may be referred to as the effective span which will include bearings.
