Does thermostat in coldest area make sense?
The reat of the house heats to the same temp with thermostat in livingroom. I dont need it in the hall where it is colder turning on and off more often. It does not make sense
Well don't have it in the Hall then! I'm becoming increasingly puzzled about what your problem is and what advice you are seeking.
In that case no problem. but it might have been the case that the living room has large rads relative to heat loss, and when CH stops on the roomstat other rooms are too cold. Then you would need to throttle the living room rads to correct this.
