Does thermostat in coldest area make sense?
What has post 2 got to do with it? Unless your sitting in your hall or have to sit in the coldest room of your house there is absolute no sense in putting it in that space
Depending on the size of the rad and the heat loss from the hall, you could set it at say 15°C and let thr TRVs (or throttle valves if you don't have TRVs) control the temperature in other rooms. But as others have said, it doesn't have to be in the hall.
Traditionally they were put in the hall for several reasons. Middle of the house, coldest place etc but mostly because there was often a fire in the lounge which would have turned off rhe heating in the rest of the house.
Nowadays just have it where you spend most of your time
Since it’s wireless, you could try it in the room where you want the temperature controlled, following the thermostat’s positioning instructions. Keep it away from direct sun, draughts and the radiator. Does that room have a TRV? With a conventional room thermostat, a TRV set lower can shut the radiator off before the thermostat reaches its target, leaving it calling for heat. It’s worth checking how the two controls are set before comparing locations.
A plumber told me to put my wireless thermostat in the coldest area of my house which would be my hall. How does this make sense? It will just come on more often and waste gas
Was he a very old plumber?
