Having just fixed a boiler fault (with agiles help) I now have a second problem. The domestic hot water is getting nowhere near hot enough, have put the thermostat on full, waited for the boiler to stop firing and measured the water temp at tap. Am getting 110 degrees F, i think thats about 50 c. As far as im aware temp range should be 55-80 degrees c. Dont think its the diverter valve as the flow pipe to c/h isnt getting hot. Is it the control thermostat/thermo phail and if so how do i prove it???. Also someone mentioned a paddle switch might be faulty?, again how do i test it?. boiler is worcester heatslave 20-25. Any info would be greatly appreciated.
