The hot water from the storage cylinder is far too hot. I turned the timer setting to 'off' three days ago and it's still very hot - hand burningly so. The cylinder stat is set at 60. I suspect that the water is at the same temperature as the central heating system; could someone guide me about what's the best way forward please. I have a Worcester Bosch boiler installed in 2020 and regularly serviced. Vented system with HW cylinder. The CH is fine and the flow temperature is set about three quarters round the dial. From looking on the forum I suspect a sticking valve somewhere - it can't be the thermostat can it, as I've turned the water controls to no HW. Any advice will be appreciated.
