Hi All,
I have a system boiler (Glow-worm Ultrapower Sxi) where the boiler is over-heating resulting in the system switching off and fault codes F5 and F25. Before the system switches off there are rather uncomfortable grinding/banging noises focused on the heating water expansion vessel. I have had a plumber out and he said the issue is that the DHW pump is not working properly (it clicks/rapid on-off) and therefore due to poor circulation on the DHW, the heating loop and therefore boiler is over-heating. Have run through the diagnostic menu and the banging noise is happening as the flow temperature (d.40) goes over 85 degrees. He believes the DHW pump is OK and recommended replacing the PCB. I wanted other's thoughts on this as I don't want to replace the PCB if the pump is the issue or potentially something else.
Here are some other tests I have run which hopefully can assist with the responses:
1/ I have run a multimeter across the DHW pump when in operation and it shows the voltage rapidly goes from 0 to ~140V and then back again. This rapid cycling is done in 0.5 second cycles.
2/ I have checked the resistance across the DHW pump live and neutral terminals and seems fine with around 220 ohms of resistance.
3/ When I loosen the bleed screw without isolating the DHW pump, water pour/sprays out which could be a sign of knackered bearings? but have read elsewhere this is not certain for certain types of pumps (this is a WILO pump).
4/ Have isolated the DHW pump, removed bleed screw and rotor shaft is turning freely.
5/ When the system is in operation, the DHW pump is not showing as switched ON in the diagnostic menu (d.13) i.e. is 0. This is despite the Hot Water Activation (d.25) being ON.
