Door casings on solid walls
21 Jun 2006
Cambridgeshire
Hi all,
Two of the internal doorways on my house are solid 9" brick. Is it regular practice to make the door casing the same width or would you use a 4" casing then plaster the remainder?
Many thanks.
you can do either.
it is possible to fix liner across the whole width of the opening and use a knock-on to create a rebate, or use a 4,1/4" door casing and return the plaster to the remaining masonry. a timber liner would have to be specially made probably using glue, biscuits and clamps, in a workshop.
someone on this forum has used ply but i'm not sure how the edges would look, or how well it receives hinge cut-outs.
