Hi all,
I'd be really grateful if anyone could help with a problem I have.
I live in a block a seven flats, and we have a main door entry system made by Terraneo. It's about 11 years old.
We have a magnetic lock on the main door, and a phone in each of the seven flats with an unlock button. The problem is that the Terraneo system has stopped locking the main door. I've proven that the magnetic lock works, and all of the phones in each flat work for audio (two-way), but the door is just always unlocked -- it must be something internal with the system.
What is the best way to proceed to fix this?
My idea is to install a new system and use the current wiring that exists. How easy would this be? I just need to replace the base station unit, but would I need to replace the phone in everyone's apartment?
The current system wiring is labelled 1, 3, 4, 5, 6. I assume this relates to the new Z, T, O, R, I wiring system? That means four common wires and one unique to each apartment.
Can I just switch the systems over?
Thanks a lot!
Davood
Thanks a lot!
Davood
