door fault Hotpoint wd860
14 Sep 2014
Lancashire
Hi
I have a Hotpoint wd860 washer dryer, two nights ago while on a hot wash it tripped the socket fuse in the main fuse box, after checking a few things I found out when I shut the door it tripped the fuse.
Reading on the internet it all pointed to the door interlock switch so yesterday I replaced the door switch, now the machine stops on but when you try to run a cycle after a few minutes nothing happens and it flasher door on the panel.
Has anyone had this problem?
Many thanks
