UPVC front door. When I press the lever handle the latch does not retract fully. It remains protruding by about 5mm. Is this normal and the fault lies elsewhere?
If this is the issue then do you know if it possible to just replace the latch operating mechanism (presumably this sits inside and behind the main linear plate of the door edge) or, will I have to replace the whole mechanism down the full length of the door, to include the upper and lower roller 'bolts' and hooks?
