DOOR openings
25 May 2007
Essex
I am making some openings in walls and putting up studwork etc.
Could someone tell me what width the door openings should be to fit a standard size frame in. Is it 800mm ? and is 762 the frame size. these sizes seem to ring a bell.
Cheers in advanced
Steve
Hi Steve
It all depends who you get the door linings from. Your best bet is to purchase the linings assemble them and then measure the overall size.
Doors come in standard sizes, have look here;
http://www.thediyworld.co.uk/internal_doors.html
Don't waste your time making door linings, you can buy them ready cut & rebated for around £10 (builders merchants, Wickes, B&Q etc. all sell them). Buy the linings & fit them as you build the stud/block work so they are accurate, that way you shouldn’t have to plane the doors to fit. Linings come in 2 widths to suit either 3 or 4 inch stud/block work & will be slightly wider to allow for the plaster.
It’s worth remembering 762 x 1981mm is the most popular size & this is the one you get the big discounts on; other sizes, although standard, may be quiet a bit more expensive.
the exact external measurement of the casings i use is 804mm, this is to suit a 762mm door.
we set our stud openings at 812mm to allow for a fitting gap.
when knocking through brickwork we will often make a larger 915mm, or 4 bricks wide opening. we will then fix a piece of 100x50mm sawn timber up each side of the rough brickwork allowing us freedom to fix the casing where we want, as opposed to where the brickwork will allow.
any larger gaps in the carcass timber can be either be filled with builders foam or mortar.
